Morini 250 Frame
Morini 250 Frame
250 Frame in Good Condition, Based in Leicester, Can help with Delivery if needed. £199
- PXL_20240603_192609512.jpg (329.44 KiB) Viewed 4209 times
Re: Morini 250 Frame
Do you have a registration number with it and possibly the V5?
(I've a complete spare rolling chassis for a 250 2C so don't need your frame, I'm asking for others
Is that a crease in the LH side lower frame rail or do 250 frames have that as std?
There are two creases on the LHS of the 250 frame rail(at least on the ones I have) there's the one visible in the photo and another smaller one further around. Both are for access. I haven't seen/noticed any on the RHS frame rail when I checked my frames. The 125 H frame doesn't have these creases (or at least the frame I have from a late 125 H (T) with the fibreglass bodywork doesn't.simonnorthroad wrote: ↑05 Jun 2024 10:44 Is that a crease in the LH side lower frame rail or do 250 frames have that as std?
For anyone interested, here's a photo of why the dents are in the LHS bottom frame tube, for the clutch cover to be removed and fitted more easily than otherwise would be the case.
PS: the wiring is loose as I've yet to work on the wiring loom.
Every day's a school-day Julian! thought they looked a bit neat for crash-damage
