Now what?
Re: Now what?
The exploded view in the workshop manual only shows & states a 'complete clutch'.
The code is M1614030. No 9 on the list.
Maybe a start in the right direction?
- Screenshot_20240619_162535.jpg (269.8 KiB) Viewed 14184 times
- Screenshot_20240619_162100.jpg (166.04 KiB) Viewed 14184 times
Carpe Diem Nil Desperandum
Re: Now what?
It is item 20 freewheel that I think is the issue
- 1B78896B-B533-41A8-B4E9-746C19EA27E1.jpeg (79.98 KiB) Viewed 14177 times
Re: Now what?
I have not had a chance to have a proper look but it could be using a similar cam shaped roller bearing as Ducati, that only grip one way and slips the other. When I have had problems with Ducatis I have always shortened the spring which works every time, just guessing here, if anyone knows better, I would be interested to know.
Re: Now what?
Ah cool i did see a video when someone did the same and shortened the spring. But I want to make sure it’s ok. I have ordered a flywheel puller. Has anyone got a sketch of the tool to hold the generator rotor flywheel thingy?
Re: Now what?
According to the manual....
- Screenshot_20240711_154836.jpg (18.81 KiB) Viewed 13974 times
Re: Now what?
Thanks I have bought one of those it’s the other bit that goes inside the rotor to hold it while loosening or tightening the securing bolt
Re: Now what?
Hi Tinker,
You can find a picture of the original tool in the parts' list M00100006400. Here are two pictures of a homemade version.
Best regards
Robert
Best regards
Robert
- IMG_1170.jpg (78.37 KiB) Viewed 13934 times
- IMG_1169.jpg (77.49 KiB) Viewed 13934 times
Re: Now what?
Great thank you Robert do you have the rough dimensions? I will get one made
Re: Now what?
Hi Tinker,
I am currently travelling and can only send them when I'll be back home on Thursday. The former importer März in Germany sells the original tool for about Euro70, but I don"t know whether they ship to the UK.
Robert
Robert
Re: Now what?
Thank you Robert there is no rush
Re: Now what?
Hi Tinker,
here are the dimensions:
Discs
- Outer diameter: 110mm
- Inner diameter: 50mm
- Thickness discs: 5mm
I ordered them on ebay for about 2€/piece
Height = axial distance discs (outer surface-to-outer surface): 42mm
Pins
- Diameter pins: 8.5mm
- Distance pins (center-to-center): 80mm
- Protrusion: 10mm
Best regards
Robert
Discs
Pins
- Protrusion: 10mm
Best regards
Robert
Re: Now what?
Thanks Robert that is awesome I will get the welder out!
Re: Now what?
No problem. A piece of plastic tube (see photo) between tool and flywheel centers the tool and helps to overcome magnetic attraction
