Head set cup for Morini singles
Stempy
Post by Stempy »
Wanted as per title headset bearing cup for Motor Morini 98 or any other single as after a bit of research I believe they are the same size, cup outer diameter 49 mm, total length 24 mm, headstock ID 32.5 mm
Re: Head set cup for Morini singles
Post by simonnorthroad »
Just checked the Ducati ones I have.
OD is correct in the ones I have, headstock measurement is wrong, sorry
