Hello - I have a 500 SEI-V Sport and am having trouble starting the bike. The starter has new gear oil and works just fine, but when I hit the starter is runs slowly, then lugs, then runs slowly, then lugs, etc. I finally got it started and it will rev to 7K just fine, Good battery. I did tune and sinc the carbs, when warm it idles O.K. and it runs great at 65 - 70 mph!.
So, when I did get it warmed up, I put a strobe light on the hole in the side case and at 5 to 6000K RPM it showed dead on the AMT-1 (30 deg advance?) mark under the cam nut.
Here is the weird part: when I dropped the throttle to low idle, the strobe shows about 25 deg advance (assuming the DMS-1 mark is 0 deg), so it is not dropping to 5--10 deg and is probably about 20-25 deg when trying to start. Thus the lugging at with starter on.
Has anyone had this problem?
Any suggestions on fixing the timing problem?
Many thanks.
Ciao Pete
500 Ignition Timing Problem
Re: 500 Ignition Timing Problem
I had this on my 250 2C - front cylinder stuck on full advance, this being controlled by the transducers. I changed the transducers which cured it, but then the pick up turned out to be a bit dodgy.
These were unavailable at the tie, so I went with an replacement system from SWF which transformed the bike! Knowing what I know now, I wish I'd have done it straight away. As a bonus, I had to convert to 12v so I have better electrics too.
Thanks for the answer. I will get a new ignition system.
Any info to compare SWF and Sachse?
Pete
Pete
I went with the SWF kit as it come complete with coils, wiring and even mounting brackets. Considerably cheaper than the Sachse kit. I have used Sachse on other bikes though with no problems
