Corsaro indicator lenses
Ratty
Post by Ratty »
I've lost three in the last month as the tiny lugs which hold them in place break off. Morini will only sell an entire indicator unit and not the lens cover so....try EBay Mini/Micro Motorcycle Indicators from bikervalue. £20 for four when Morini ask £23 for one and they look good. I've fitted the arrow shaped ones which took twenty minutes. :D
Emmohaswheelsagain
Indicator Lenses
Post by Emmohaswheelsagain »
This is one standard item which is clearly not fit for purpose. I've lost one on my 9.5 and will probably loose more. They are easy to knock particuarly by the pillion when they are getting on & off the bike. I will look to replace mine the next time I loose a lense.
twisty
Post by twisty »
tried to change a bulb on mine and the fitment is totally corroded. Bought replacement led items and will fit them if they don't invalidate the warranty.
nfitz
Post by nfitz »
I removed mine as they looked cheap and fitted some iridium lenses of the www for £30 a set. - keeping the old one for retuning th ebike to origional condition when/if i sell it
