Vhb25b carb
caddy4037
Vhb25b carb
Post by caddy4037 »
Looking for the screw on piece for my carb that attaches to the air filter pipe.
The end that fits into the air filter pipe is 40mm.
Please take a look underneath your bench as I cannot find one on line.
Thanks, Frank.
dunk 1
Re: Vhb25b carb
Post by dunk 1 »
https://www.dellorto.co.uk/shop/dellort ... m-plastic/
Is this possibly it? Difficult to compare with the black colour - apologies if I'm mistaken - Duncan
dunk
caddy4037
Re: Vhb25b carb
Post by caddy4037 »
Good spot Duncan and thanks for looking, I had seen this but hopefully can turn up an original one if possible.
All the best Frank.
Re: Vhb25b carb
The originals on the early carbs were made of something like mazak and are prone to crumbling. Quite risky as any bits get sucked into your engine.
I replaced mine with the plastic parts off a later Morini carb, which are a straight swap. I couldn’t recommend any reason to refit metal ones
caddy4037
Re: Vhb25b carb
Post by caddy4037 »
Cheers Tom,
As you can see mine did the crumbling thing.
I was thinking last night after Duncan's suggestion that the plastic part might be the way to go especially as it won't be seen.
All the best Frank.
Re: Vhb25b carb
caddy4037 wrote: 24 Feb 2025 08:19
And especially as rivet counting was outlawed in this club years ago. :wink: Unless it's me of course...
dunk 1
Re: Vhb25b carb
Post by dunk 1 »
There are grey plastic ones on my 79 sport, It is news to me that earlier ones were made of anything different - hence my post.
Duncan
dunk
caddy4037
Re: Vhb25b carb
Post by caddy4037 »
Cheers guys, I've ordered 2 of the ones Duncan recommended...and I'm adding lightness.
Thanks Frank.
