Centre stand.....
TimClarke
Centre stand.....
Post by TimClarke »
Is it just me, or does the centre stand on the 500 require an above average amount of effort?
Rocker62
Re: Centre stand.....
Post by Rocker62 »
Hi Tim, if my centre stand is the norm it is just you !!
Steve.
TimClarke
Post by TimClarke »
Rocker62 wrote: 10 Mar 2025 18:14 Hi Tim, if my centre stand is the norm it is just you !!
Steve.
I'd better have a close look then to see if anything's bent!
It shouldn't be too bad to use unless it's bent or damaged somehow. A 500 will feel heavy though compared to a pre electric start 350.
Post by simonnorthroad »
If your pivot points are worn or the frame bent then the rear tyre will nearly be touching the ground (depending on the rubber profile) and you will have more to lift/further to heave
TimClarke
Post by TimClarke »
simonnorthroad wrote: 16 Mar 2025 12:15 If your pivot points are worn or the frame bent then the rear tyre will nearly be touching the ground (depending on the rubber profile) and you will have more to lift/further to heave
Cheers, I think it maybe just a combination of wear and tear on me and also being used to more modern bikes' stands
