Electric Starter fault
Emmohaswheelsagain
Post by Emmohaswheelsagain »
Great weather today so decided to give the bike and me a short shake down after fitting a new battery.
No real issues until I returned home. The bike failed to start on the button, just a loud click from the relay.
The bike has a solid state Durit relay, no visible fault, earth ok, wires fine, strange that the fault appeared after a 20 minute ride, never done this before. Any ideas?
Re: Electric Starter fault
Have you had a meter on the wire to the starter to see if you get 12 volts when you press the button?
Emmohaswheelsagain
Hi Micky, hope you are well.
With regret I must report that there is adequate power reaching the electric motor. :(
Paul
Yes thank you, Paul, all good here in the tundra. Hope you are good, too.
Brushes are next stage.
Emmohaswheelsagain
I thought so, I need to give the starter a general overall, weak legs makes the electric boot essential these days, extra gym sessions doesn’t seem to compensate for the wear and tear that comes with age :(
Emmohaswheelsagain
Do I need any specialist tools to remove the electric start.
Not sure whether to leave it on the bench or have the starter repaired.
In recent weeks I have used the kick start without to much effort.
That said the e/start can be useful as back up.
Paul
Stempy
Post by Stempy »
No just a 5mm Allen keys and a 17mm spannerto remove the starter shoes plus the chain , the starter shoes can be a bit tricky the center bolt is 17mm with a flat in the middle to hold the shaft when undoing the nut , some people make up a spacer for the bottem left bolt so you dont danage the casing form overtightning .
Emmohaswheelsagain
Thanks for the heads up. :D
Emmohaswheelsagain wrote: 13 Jul 2025 08:24 Do I need any specialist tools to remove the electric start.
Paul
The electric start is essential when stalling in gear in traffic!
Assuming it is the motor not turning, I just remove the motor and unhook from the chain. The starter clutch can be left in situ.Take photos as an aid memoir.
I mark the starter cases to help rebuild, thought that’s not essential especially if you take a couple of shots.
( e.g. Ardbeg etc) . Hopefully once the two long bolts are out you will find an issue with the brushes area.
But try the motor direct to a battery first.
Also see
https://m.youtube.com/watch?v=UfZv2OtD7Rc
Emmohaswheelsagain
Thanks Mike, John for the response.
Mike - I remember from an earlier life that the electric button has its uses, especially two up in traffic.
These days I ride without a pillion and mostly around the many country lanes close to Louth.
This means i can avoid traffic and the possibility of stalling.
That said I do intend to restore the electric start to its working best, although I will probably use it sparingly.
Your suggestion John to leave the starter clutch in situ is a good one, so hopefully it will be a simple fix with new brushes.
As always there will be more to do, part and parcel of owning a 46 year old motorcycle. :D
Thanks again.
Paul
