Rear axle washer/spacer.............
TimClarke
Post by TimClarke »
It's taken ages to sort out the discs on the 500 and I've made the rookie mistake of not recording image sof where the 2 washers you can see on the axle go and now I've forgotten
It would be really handy if anyone could tell me and sa
ve me a heap of experimenting!
Thank you
TimClarke
Re: Rear axle washer/spacer.............
Post by TimClarke »
These images show a bit clearer the items that Id like to check where they go on the axle please!
Tim
Post by Tim »
Try the 500 parts book for an exploded diagram - there should be one in the library
The washers go under the nut on the left side and the outer end of the long through spindle on the right/drive side
TimClarke
Post by TimClarke »
Cheers, and does it matter which way round the spacer goes?
Tim
TimClarke
Post by TimClarke »
Tim wrote: 22 Jun 2025 09:26 Try the 500 parts book for an exploded diagram - there should be one in the library
Cheers, Ive got that but it's not entirely clear
'Cheers, and does it matter which way round the spacer goes?'
Yes, the smaller diameter end fits in the bearing oil seal - note there is no oil seal fitted in your photo
TimClarke
Post by TimClarke »
Oh dammit I suspect I've got a missing part then - any ideas where i could get one of those oil seals from?!
TimClarke
Post by TimClarke »
The parts list will tell you the sizes usually and any bearing stockists should have them. All common sizes.
TimClarke
Post by TimClarke »
I have got a parts list I'll have a look cheers
TimClarke
Post by TimClarke »
'It must be a .....' wrote: 22 Jun 2025 15:48 'Cheers, and does it matter which way round the spacer goes?'
hAVING LOOKED AT THE PARTS DIAGRAM it looks like there's already a seal on the inside of the circlip and it doesn't show another one?
