Rear shock absorbers - 300mm
I would like a new pair of rear shocks and would be grateful for any recommendations. The current ones are 300mm between the centre of the mounting holes. Many thanks
Re: Rear shock absorbers - 300mm
YSS if on a budget, Protech if looking to spend Koni/Ikon type money but want something state-of-the-art: multi-adjustable preload and damping, light, custom-built for your combined-weight/useage, rebuildable, UK-made
You could try YSS, i have had a a set for another motorcycle and found them excelent ,
http://www.yssshocks.co.uk/products.html
Eco line ?
Eco line ?
cHEERS!
Hello ,
I just have a look at your subject . In fact 300mm between centers are only for 350 .
On the 500 the rear fork is longer + or - 60mm compare to the 350 .
Than on the 500 the shocks the lenght is 320mm between centers .
Christian , 123 .
Christian , 123 .
- The lenght of a 500 .
- IMG_0696.JPG (202.99 KiB) Viewed 2685 times
- And here the lenght of 350 .
- IMG_0694.JPG (248.82 KiB) Viewed 2685 times
Re -
Here are photos of the lenght of shoks .
- the 350
- IMG_0687.JPG (165.11 KiB) Viewed 2684 times
- the 350
- IMG_0686.JPG (197.46 KiB) Viewed 2684 times
Re-re ,
The lenght of the 500 ...
Christian , 123 .
Christian , 123 .
- The lenght of 500
- IMG_0690.JPG (103.93 KiB) Viewed 2683 times
- The lenght of 500
- IMG_0688.JPG (224.47 KiB) Viewed 2683 times
Nice to see the frame next to the brake fluid reservoir has not been damaged by brake fluid weeping.
Judging by other posts on the forum & my own measurements, something nearer 312mm eye to eye is correct for the 500
Cheers matey
