Steering lock
barney 66
Steering lock
Post by barney 66 »
Any pointers where I can get a steering lock for my 76 31/2 Strada please ? Mdina says out of stock, I know there not the best thing but would be ok while calling at local places where i’m near the bike
Thanks barney
Re: Steering lock
They use to be Neimann locks
AntietamClassicCycle
Re: Steering lock
The same lock is used on Moto Guzzis, so try Gutsibits.
https://www.gutsibits.co.uk/pr/TheShop/ ... rch=SEARCH
barney 66
Re: Steering lock
Post by barney 66 »
Thanks, maybe I should try and remove it first to make sure, any tips to remove it ? I have no keys
Thanks barney
Re: Steering lock
barney 66 wrote: 10 Oct 2025 14:48 Thanks, maybe I should try and remove it first to make sure, any tips to remove it ? I have no keys
Thanks barney
I used the Guzzi lock in my '77 3 1/2 Strada.
You could have a locksmith "pick" the lock and make keys. As Norbert wrote, it's a Neiman lock, so keys for a BMW Airhead seat lock will be the same. Here's a list of other blanks: https://www.thisoldtractor.com/moto_guz ... _lock.html
If you don't have keys and can't have some cut, then the lock will be destroyed removing it. Here's how I do it. First, remove the cover, which is accomplished by using a thin bladed tool to pry under the cover at the rivet. Then use a punch and hammer to drive the lock inward - this breaks off the head of a tiny screw in the lock bore that secures the lock. You should now be able to pull the lock out. It's helpful if you can line up the groove in the steering stem with the lock before doing this.
barney 66
Re: Steering lock
Post by barney 66 »
AntietamClassicCycle wrote: 10 Oct 2025 16:54
Thanks barney
Great Thanks for the detailed response, if that’s the lock that fit yours then mine should be the same being a 76 31/2 Strada so maybe I order first then I can see what Im doing
Thanks barney
dunk 1
Re: Steering lock
Post by dunk 1 »
If you search this forum for a post by dvhttm titled missing parts _ replying to another post there is a link to a bmw site with information on how to remove the locks - sorry thus is a bit roundabout but I cant copy the link very well on this device - Duncan
dunk
dunk 1
Re: Steering lock
Post by dunk 1 »
This is the post with the link referred to above - the link is to an old BMW site and has a lot about how to remove these locks.
viewtopic.php?f=4&t=2093&p=10072&hilit= ... ock#p10072
dunk
Guzziando
Re: Steering lock
Post by Guzziando »
This video explains it well. I drilled a hole where he suggests:
[urlhttps://www.youtube.com/watch?v=euRfvhFmGrc][/url]
The lock is the same as the VESPA ET3 PRIMAVERA SPRINT RALLY MK1 PE PX P200, for example: https://www.ebay.co.uk/itm/154548382718
barney 66
Re: Steering lock
Post by barney 66 »
Steering lock now all sorted so Thanks for everyone’s help, couldn’t pick the lock tried with different lock picking tools for over an hour then resorted to the drill using one of the links posted here for drilling position.
Purchased the lock via the link on here to the vespa item, as stated it was identical as the old one
Thanks again to everybody’s help
