501 intake rubbers carb to head
Excaliburs, New Yorks
steveyhod
Post by steveyhod »
Hi
The intake rubbers on my NY are stamped MM32. Are these correct for a 501? Any advice welcome.
Thanks in advance
Steve
Re: 501 intake rubbers carb to head
Yes MM 32 is correct. They are not the same as the 500 ones.
Post by simonnorthroad »
What's the difference I wonder?!
The inlet tubes of the heads have another diameter. The carb side should be the same (I guess, beeing PHBH the 26/500 and 28/501).
With force you can mount a 500 inlet rubber, but I wouldn't do that.
