OK so I've had the GP for about 6 weeks and I'm already hatching a plot re the wheels.
Looking at options re more sports size wheels ie super moto type thing.
Being lazy I thought I'd ask if anyone knows what the front and rear wheel bearing sizes /codes are and also the sprocket carrier????
R
GP wheel bearings
Re: GP wheel bearings
Hello.
Front wheel: 6005 (x2)
Rear wheel: 6006 (x2)
Sprocket carrier: 6006 (x2)
All bearings sealed.
Thanks for that.
If they are the right bearings the front wheel swap looks easy, almost a straight fit.
I may need to get creative with the rear though. Bit of a miss match on the bearings and a straight bearing change to fit doesn't look possible at a first check. I also need to space out either the disc or sprocket carrier to make it line up, RSV is about 6mm narrower than the GP.
I'll post further details when I get a change to look further.
