Reinstating the electric starter part 2
Well all the electrics are working but....
It appears the customs have a different electric start casing, so the gear linkage fouls!
Does anyone have a spare standard electric start side casing?
Simon
Simon
Re: Reinstating the electric starter part 2
I would not think Morini could afford a different casing.
Has the linkage been changed, do you have rear sets?
Of course, I could be wrong, not unknown!
As far as I know tere are two diferent casing for Street- and Enduromodels. And of course the casings for the Kokussan alternator
Standard K1 linkage, case is definitely different, am I right in thinking the customs were left hand shift, which may explain it. I believe the off-road bikes were more cut away but may well work.
Can you post some pictures of what you have?
As above, I don’t believe there were any differences in the electric start case for the road models.
I’ve not got a decent picture of my k1 before I fitted rearsets but below is a picture from the sales brochure of the standard setup, and one of my bike now with rearsets and the longer cranked linkage
- IMG_8246.jpeg (165.21 KiB) Viewed 6611 times
- IMG_8247.jpeg (257.63 KiB) Viewed 6611 times
I have had the exact same K lever just touch the case and cause a selection issue. This simply required adjustment of the linkage. I think a friend had similar last year.
If the linkage rod is not a standard length ( I wished I had made a note of that when I made one from stainless steel) or cannot be adjusted to clear the case check that rod length.
I also am unaware of different e-start cases.
Measuring my rod, from the centres of each rose joint gives 151 mm ( home made rod)
'It must be a .....'
Trust this helps
Could alter the Excalibur cover?
- top 500 road below 501 Camel (1).JPG (129.01 KiB) Viewed 6588 times
- top 500 road below 501 Camel (4).JPG (135.09 KiB) Viewed 6588 times
Thanks guys, the case I have looks like the camel one. I have been looking at pics of my old Morini K, the linkage looks the same but the casing I have is definitely deeper. So cutting back won't work, so the hunt for a roadster case continues.
Attached are pics of my old bikes one and the one I have.
Try checking the “bits for sale” section at the moment, might be a case in amongst the parts ex Barcelona?
It was worth me looking at my gear linkage yesterday. The lever action was stiff. This turned out to be as a result of me trying to take up wear in the pivot bush/ frame using some thin shim metal last year. Some kind of corrosion I expect. Removed shim and much better but wobbly.
