"A" Cam Pulley vs. "B" Cam Pulley
smotorboy
Post by smotorboy »
Hello All,
A question for the Morini Motor Mavins in the UK….
I have an "A" pulley installed and the belt tension is a little too loose for my liking.
Question: If install a "B" Pulley (which I have) will it tighten up the tension or loosen it more???
Thank You in advance for your expertise,
Robert "Smitty" Smith
Red Baron LSR
California
Re: "A" Cam Pulley vs. "B" Cam Pulley
it will tighten up.
A is the smallest pulley, C the largest and B is suposed to be the norm.
0.15mm difference in pitch diameter.
