Shop full of Spares. Stock from closed dealer in Barcelona
Tom
Re: Shop full of Spares. Stock from closed dealer in Barcelona
Post by Tom »
Yes I used an exhaust clamp.
Here you go:
Team Buffoon
Post by Team Buffoon »
Thank you for the pictures makes it very clear and thank you for the other responses.
michaelt
Post by michaelt »
Do you have any of the chain idler wheels for a Camel 501.
Cheers.
Michael
ianlucas006
Post by ianlucas006 »
Hi Michael.
Away at the moment. I suspect not but will check when back. They are available. I am sure there was a discussion in Green Lane group recently. I do have a complete 501 Camel if you want another one. Just picked up in France! Thanks Ian
Al B
Post by Al B »
You haven't by any chance got a Sport speedo cable have you?
ianlucas006
I don't think so but will double check when I get 5 mins. Thanks Ian
chrisMorison
Post by chrisMorison »
Hi mate, Any 260mm discs?
Chris
ianlucas006
Hi Chris
I may have but would cost a fortune to post to Australia! Which model as there are different hole centres and offsets.
Thanks Ian
chrisMorison
75 350 Sport wire wheel.
It's 260mm x 25mm offset 6 bolt
Yes postage is a pain in the crack but I can't find one here. A Pantah disc might fit but they're pretty thin on the ground too.
hombre
Post by hombre »
chrisMorison wrote: 30 May 2024 00:36 75 350 Sport wire wheel.
Th Pantah ones probably have a larger offset, bolts, ø are the same
Post by simonnorthroad »
Hi Chris,
Ive got several Morini 260mm Grimeca discs here in the UK. They will weigh a ton to post though.
Pantah/Guzzi Brembo discs have a deeper dish.
I can send photos/get you a quote if you are stuck. I post books to OZ all the time
PM me or email: moriniboy23@yahoo.co.uk
ianlucas006
Hello Chris. I have tracked down the disc. It is a bit scruffy as the chrome has worn away as they do. Post to Aus is about £40! Which is more that I would want for the disc. thanks Ian
vtwinanyday
Post by vtwinanyday »
Thanks I found lots for sale on ebay. I ended buying one from Italy after weighing up price v postage.
Cheers Chris
Team Buffoon
Hi Ian - Merry Christmas,
Do you have a set of fork gaiters for a 501 Camel? 40x50mm x 29cm.
ianlucas006
There are some NOS aftermarket ones in red. Top and bottom diameters are good for 501 forks. The overall length is about 40mm longer and the diameter on the bellows section is slightly larger than the originals. £10 Plus what ever the post is (prob about £4)
Thanks Ian
