Hi Michael.
Away at the moment. I suspect not but will check when back. They are available. I am sure there was a discussion in Green Lane group recently. I do have a complete 501 Camel if you want another one. Just picked up in France! Thanks Ian
75 350 Sport wire wheel.
It's 260mm x 25mm offset 6 bolt
Yes postage is a pain in the crack but I can't find one here. A Pantah disc might fit but they're pretty thin on the ground too.
chrisMorison wrote: 30 May 2024 00:36
Th Pantah ones probably have a larger offset, bolts, ø are the same
Hello Chris. I have tracked down the disc. It is a bit scruffy as the chrome has worn away as they do. Post to Aus is about £40! Which is more that I would want for the disc. thanks Ian
There are some NOS aftermarket ones in red. Top and bottom diameters are good for 501 forks. The overall length is about 40mm longer and the diameter on the bellows section is slightly larger than the originals. £10 Plus what ever the post is (prob about £4)
Thanks Ian
