Can ignition left on damage components?
As the ignition system is independent of the battery, would I be right in saying that if you left the key switched on there is no potential for damage to coils, transducers etc?
- George 350
Re: Can ignition left on damage components?
You are correct. No damage can occur to the ignition system.
YES - in my opinion, this may cause a problem with fuel leaking into your sump, if you have worn needle valves, as your electronic fuel tap will be left open (as I understand it?).
Dom
Dom
This might be a factor but despite my switch giving a hearty clunk at turn on, it passeth not a drop of fuel! Anyone taken these apart and repaired?
Not me, but I suggest asking in a new thread, if there's no joy when searching for a previous one. (I know some people have changed to two manual ones, though.)
Dom
Dom
It may simply be clogged up with varnish, rust, and silt.morteach wrote:This might be a factor but despite my switch giving a hearty clunk at turn on, it passeth not a drop of fuel! Anyone taken these apart and repaired?
Mine used to work most of the time, but has become increasingly inadequate for 60mph+ running. That's probably the diaphragm being affected by modern fuel. As far as I know there is no replacement available.
Hello - I stripped and cleaned the electric tap when I got my bike but it only improved slightly from zero flow to very little - again I believe that it's the diaphragm that is the issue - possibly stiffening due to age and again I was informed that they are no longer available -Duncan
dunk
