APTC clutch
APTC clutch
Hi all
MM have the updated APTC clutch on offer for €720/£613 from €1027 limited offer until 31may 2013, has anyone got the 2013 model bike which these are fitted to ? .im tempted to get it , if there is any interest in my hepco Becker Ali panniers ? ,which I can't actually use now I have the GPR exhaust fitted . £420 including p&p uk only .
http://www.motomorinimotorcycles.eu/ind ... 58&lang=en
Re: APTC clutch
I have the hepco frame fitted with GPR exhaust? what do you mean doesn't fit ?
Re: APTC clutch
When i first put on the exhaust ,It looked like I would have to modifiy the rear bolt mounting point of the frame to get clearance for the exhaust hanger . Any chance you can post a photo of your set up ? Or email me. Photo ?
Re: APTC clutch
i will make some pictures and mail them bit it will take a few days.
What i needed tot do was buy a longer bolt if I remember, also added some extra washers (I think that is the correct word, round flat rings tha you install between a bolt and a nut)
But i will make some puctures and send them.
I installed exhaust and frame at the same time, i had the impression that frame and original exhaust would give me a problem ...
GPR is slimmer and fits fine
I did ad givi hooks on the hepco frame something "homemade" so if you see the pictures it is no Givi frame
My biggest problem was to fit the givi topbox rack in combination with the HB rack, this givi rackI had to adapt.
Re: APTC clutch
I bit the bullet an bought a aptc clutch via the mm site (£661/€748) Quick delivery to my local mm dealer ,mota corsa in dorset . Ordered 13th April received 26th April . Plan is to drop off the bike this sat and pick up next sat . Oil and filter change while its being done and mot . First one mota corsa have done ,gulp! . Get to play with a fireblade or benelli TNT curtesy bike for the week too. I'll report back on the clutch .
Re: APTC clutch
Hi all ,dropped off the bike to moto Corsa this morning ,leaving it for the week ,to have the clutch changed mini service and mot . I thought id take a photo of the clutch as ill never see it again . see attached photo of the 2013 Adler APTC clutch .
Re: APTC clutch
At that price I expected the colour to be gold....
butchamphib
Re: APTC clutch
Was there problems with your old clutch? Mine is slipping at 16,000 miles.
Re: APTC clutch
No ,my existing clutch is ok , I just wanted to take advantage of the mm sale .also having a lighter clutch will be a lot less tireing when stuck in traffic .i will be keeping the old clutch for reinstalling if I ever sell the bike .
Re: APTC clutch
I take it that was your bike I was looking at when at Motocorsa on Saturday then, it appeared to be in good condition and well looked after.
Nick
Nick
Re: APTC clutch
Yes ,that my my grey beast ,still needs a bit of TLC here and there but goes well .
What was the purpose of your visit to moto corsa ?
Re: APTC clutch
Picking up my Corsaro after replacement of chain and sprockets.
Re: APTC clutch
Ah ,that would be your black and silver corsaro in the workshop then .
Re: APTC clutch
That's the one, lurking at the rear.
Re: APTC clutch
Yah
Got bike today . Sweet! clutch . Clutch engages /disengages as normal standard ,lever action is as promised 50% easier to pull . Highly recomended mod if you have the wonga spare . Mike from moto coarse recons it's very trick !
Standard clutch
Standard clutch
