My Strada
My Strada
Hi All,
Bought this Strada off eBay as a spares donor for my Sport 6 years ago.Didn't have the heart to break it in the end, (is just 24 bikes newer from frame number) but I didn't do anything else with it either until the end of 2011.
Much stripping, cleaning, new bits, plating, spraying later I'm nearly done. Just waiting for the correct kickstart back from the platers and to finish machining the indicator stems and I should be done. Engine runs with the new 'home made' ignition system.
As bought
As bought
02as bought.jpg (100.58 KiB) Viewed 33856 times
Left side
Left side
right side
right side
Only 'bah' was that the seat cover cracked when I sat on it! Yep, hadn't touched the seat as it was perfect apart from a small amount of surface rust on the base, so I was going to use it 'as it was' but obviously 35 year old Italian vinyl has a limit to how flexible it can be. Next stop Leightons in Birmingham...
Shameless Plugs for other excellent suppliers I have used:
AE Pople - Speedo glasses and bezels
Hockley Enterprises (Southend on Sea) - All Chroming
Action Electroplating (Basildon) - Zinc plating
Vulcan Powdercoat (Basildon) - All the black bits powdercoated
Auto Effects (Barton Le Clay, near Luton) - Silver paintwork
NLM - Having all the missing bits and required bits when I needed them
Disco Volante - Stainless fuel cap
Apart from work done by those listed above, I have done all the rest myself.
Usual caveat - No connections with any of the above suppliers other than as a satisfied customer.
Now I have a pair of bikes just like the 1978 advert!
Re: My Strada
Some more pics:
16strada tank.JPG (127.65 KiB) Viewed 33855 times
12my bikes.JPG (150.03 KiB) Viewed 33855 times
26 strada engine.JPG (143.53 KiB) Viewed 33855 times
Daddy Dom
Re: My Strada
Post by Daddy Dom »
Beautiful, George. You can recreate the ad in your garage.
When you get the seat cover, please report back. I bought mine a few years back and only just fitted and it turns white in the wet or just with water spots - Leighton's are baffled and have offered to replace but it does clear up when dry. Must be our NZ rain.
Dom
SPEIRMOOR
Re: My Strada
Post by SPEIRMOOR »
Beautiful!
chirpy999
Re: My Strada
Post by chirpy999 »
A lovely job there George, thats better than when it left the factory!!
Re: My Strada
You might want to consider buying a new seat from NLM. The seat foam degrades with age and the cost may be very similar if replacement foam is factored in. Nisa (the OEM supplier) only do the early short Strada seat however.
My new Sport seat has very good foam and very flexible modern vinyl.
acemorini
Re: My Strada
Post by acemorini »
very nice George, top marks. Pete. :)
mantaray
Re: My Strada
Post by mantaray »
Very nice ;-)
buell1203
Re: My Strada
Post by buell1203 »
Bought my seat cover from leightons some time ago but have yet to fit it. I was disappointed to see the script on the rear is smaller than the original. Is this the norm?
robint
Re: My Strada
Post by robint »
Had my seat done by Leightons a couple of years ago - seems identical to original in wording size, no sign of white spots and a lot more comfortable.....quite happy!
robint
buell1203
Re: My Strada
Post by buell1203 »
I bought a seat cover from leightons but the font was wrong, ie too small. I mentioned it to andrew last week but it appears the small font is all he is aware of. Not the end of the world but a pity to have to use the wrong type.. He has no plan to produce the larger script as it would prove too expensive. A point worthy of note if originality is paramount to those of you with early 350's.
TurboRestorer
Re: My Strada
Post by TurboRestorer »
Leightons did a great job on my seat, January this year.
ZRX1100 1999
KLR650 1990
750 TURBO 1984
SV650 2001
MOTO MORINI 3 1/2 STRADA 1981
