Noticed that my GP is leaking coolingfluid
It is where the tube is connected tot the rearcilinder. First i thougt it was the clamping of the tube that was fitting but it seems to be the nossel that is mounted on the rear cilinder
Is ther an o ring or gasket behind this part, or will it just open it clean it and tighten again,
anybody had similar problems and ideas about repairing this problem
Leaking coolfluid
butchamphib
Re: Leaking coolfluid
There i an 'o' ring i thought mine was leaking from there but it was the clips instead and it only leaked for a few second as the thermostat opened during warming up.
I replaced my hose clips with jubilee clips .. as said, they only leak when first starting up ( I presume the hose is only open while the engine is cold)but at least this way you can check and prevent it reoccurring
