penman wrote:I see you have no replies to your question, so I thought I'd throw in my tuppence worth!  I don't think operating the unit with no windings will cause any ill-effects, you may have a little magnetic drag on the rotor, but you'll have that anyway.  However, you say the alternator windings "don't work" - a very common cause of failure is short-circuit turns due to insulation failure, and shorted turns will be wasting energy and unnecessarily heating the stator.  In which case, removing the windings would probably be a very good idea.  Even if the windings are measuring open-circuit, there could also be shorted turns.
If you do achieve time travel, please come back and tell us all exactly what you did!
Joe.
Good point. I really should confirm that there is no output from the lighting coils and then do a resistance test. It could be a regulator failure coincidental with the engine swap, or even a connection I didn't attach properly. I was much more interested to see if it ran OK so was concentrating on the ignition system.
The other approach would be a more conventional ignition system running from a 'total loss' battery. That would be perfectly adequate for speed hill climbs when you can charge the battery between runs. I know there are systems like the Sachs that use conventional coils and battery, but a bit pricey. I expect an electronic whizz could build a box that the OEM pickup could trigger to fire dyna-coils with a battery LT supply, but I'm not sure if the timing curve would be right without the effect of RPM on the stator ignition winding output? The NLM module I have on the test machine uses small coils as used on scooters. It works very well so may just get another for the hill climber once everything else is sorted.
The best way to achieve a second off all my times may be to fiddle with the timekeeping software that I help the NHCA with
If RiderNo = 314 then RunTime = RunTime - 1
