Witness marks on the hub give big clues as to the original spoke orientation. Alternate holes will probably have similar on the 'inside' face. A starting point, at least.
Early sport
Re: Early sport
Looks like a good job.....you've got probably the hardest part to do. I helped a friend replace a damaged trail bike rim years ago.....looked a simple job, but what a PITA
- hub.jpg (43.46 KiB) Viewed 70109 times
1974 Moto Morini 3 1/2 Sport
1972 Moto Guzzi V7 Sport
1975 Moto Guzzi 850-T3
1976 Moto Guzzi 750-S3 (owned since new)
1978 Moto Guzzi 850 Le Mans Series 2
1983 BMW K100
1983 BMW K100RS
1974 260Z
1989 R32 GTR
1983 BMW K100
1983 BMW K100RS
1974 260Z
1989 R32 GTR
AntietamClassicCycle
Blue Morini USA
Re: Early sport
Looks great Mark. Keep up the good work !
Mepstein
Re: Early sport
Trying to get parts ready for reassembly.
- IMG_0505.JPG (88.05 KiB) Viewed 69910 times
Re: Early sport
Looking good, I am also rebuilding an old Sport, but from a pile of parts (see other post about the crank). Mine has framenumber 5009... The engine number is only applied to exportmodels, in Italy you won't find engines with numbers...
Mepstein
Re: Early sport
The engine came to me in parts. Very rough and incomplete. I've been working with someone to resolve that.
- IMG_0572.JPG (164.05 KiB) Viewed 69879 times
Re: Early sport
From the length of those drive belts you have one of those extremely rare OHC engines
1983 BMW K100
1983 BMW K100RS
1974 260Z
1989 R32 GTR
1983 BMW K100
1983 BMW K100RS
1974 260Z
1989 R32 GTR
Re: Early sport
I saw some rusy bits, but a crank that rusty is somewhat overdone... Was it underwater?
Mepstein
Re: Early sport
Yes, most of the parts were pretty trashed. I purchased a partial engine (bottom end) from a fairly local Morini owner. Found a nos racing cam and traded it for a nos sport cam. The cylinders were rusted so we bored them to 375 and purchased new pistons from NLM. We are able to use the numbers matching case so that is a bonus. I'm sure there will be other issues but one thing at a time
Mepstein
Re: Early sport
I noticed a slight difference in the front hubs between the early bike and the '74. They added a lip for a rubber seal on the drive side cover plate on the '74. On the early bike, the inside of the cover plate does not have a lip and is symmetrical (other than the opening for the speedo drive).
- '74
- IMG_0743.JPG (128.51 KiB) Viewed 69729 times
- Early
- IMG_0742.JPG (108.43 KiB) Viewed 69729 times
- Early
- IMG_0745.JPG (126.08 KiB) Viewed 69729 times
Mepstein
Re: Early sport
'74 has a lip for the rubber seal
- IMG_0744.JPG (106.42 KiB) Viewed 69729 times
Re: Early sport
Mine is the same (although a Benelli Tornado one). This rubber seal is important to protect the drum from the grease of the speedo drive. It took me a year to find one (the seal, to find the brake took some more years
Dulcinea once was a `74 Strada but has become a bit more sporty now
This project took me nearly 15 years, but now it´s done
First summer day today here in Schleswig-Holstein!
