Water pump oil seal
backfat1187
Water pump oil seal
Hello folks
To repeat a post by Stauch in 2014, I was looking for Part No. M90300005400. The diddy oil seal on the water pump impeller shaft.
I could just put the engine back together with the old one, it's probably fine as I was very careful during disassembly but I'll curse if in a month or two I have to deal with an engine full of emulsion for want of a new oil seal.
NLM, 3x, moto corsa can't help. I can get one from http://www.shop-hsi-custombikes.de/ but it'll take while to arrive and I really want to get the motor closed up in the next couple of days.
I might take it down to local supplier of such things. Surely on a modern metric bike it can't be too hard to get one. The parts list describes it as 'Baduo seal ring 10-18-5/8'. Anyone know what the numbers mean? I thought they must relate to the size but there's no way 18mm is a dimension of said part. It's much smaller.
Would welcome any thoughts
Many thanks all
Jim
Many thanks all
Jim
Re: Water pump oil seal
Hi, try use a digits what you see on seal body in internet, two years about i looked for same way. I found one seller from Romania with chip price. Now i don't have those addresses.
backfat1187
Cheers Eddydog, I'm trying to read the numbers but I can no longer read such small characters at such a short distance. Maybe 10 years ago!
However, it appears I was talking complete cr*p when insisting the seal was smaller than the numbers suggested. Having been over to measure the item, it does, in fact, have O.D. 18mm I.D 10mm with a 5mm sealing depth and 8mm total depth. No doubt when I find my magnifying glass, the numbers on the seal will confirm those dimensions.
What a numpty.
What a numpty.
Jim i will ring the company i use in the morning they are really on the ball i will let you know how i get on
backfat1187
Super, thank you John.
It's the same seal as an Aprilia RS 50 or minarelli scooter engine... Repair kits easily available on ebay for about a tenner... Chuck what you don't want away or try and source a seal individually
DaveH
DaveH
Dave H
Ducati Multistrada 1200S DVT
Moto Morini Corsaro 1200
Beta RR300
Beta RR300
backfat1187
Cheers Dave.
No joy jim it is a bit of a special seal i would go with dave h advice
backfat1187
No worries John. Thanks anyway.
Jim when you set the valve shims download dave h shim calculater it is such a time saver
10-18-5/8 CORTECO A9 CFw BADUOSF
Its on seal body.
may be it will fit?
http://www.braapmotors.lv/s/params/cate ... em/267469/
Its on seal body.
may be it will fit?
- IMG_1153.jpg (242.51 KiB) Viewed 21438 times
- IMG_1151.jpg (264.08 KiB) Viewed 21438 times
backfat1187
Thank you gents. A great help. As ever.
