Gearbox whine
Maestro, SEI-V
penman
Gearbox whine
Post by penman »
Now I've managed to find something new to worry about. My gearbox whines in 3rd gear only. The whine is worst when just maintaining speed. It doesn't whine on the over-run and it whines less under strong acceleration. There is no problem engaging 3rd gear and with the engine stopped I can't detect any excessive backlash. Any ideas? I'm not (yet) familiar with this gearbox but looking at the diagram I don't see anything particular to 3rd apart from the gears themselves, so I'm guessing this is just a bit of wear and not particularly dangerous, though it'll probably get gradually worse.
1984 Moto Guzzi V65
1969 Honda CB450
1975 Triumph T160 Trident
2019 BMW F750GS Sport
1978 Morini 500
Clive
Re: Gearbox whine
Post by Clive »
Mine appears to do that as well.
Could be the first signs of impending disaster, which will almost certainly be expensive too, or it could just be a little quirk.
I'm going for the quirk until it goes pop, then I'll worry about it.
penman
Re: Gearbox whine
Post by penman »
Hi Clive,
Interesting! Is yours confined to 3rd gear as well? I like the "quirk" theory, though I've used it before and found it unreliable! I don't know anything about this bike's previous life, but if it was used in a mainly built up area, I can imagine 3rd gear getting a bit of a hammering, and the whine is probably down to wear and tear. I think I'll keep an eye on it for the time being. If it starts to get worse it'll have to come to pieces, but that's a full strip-down on this engine as far as I can see. They do keep you busy, these old bikes!
1984 Moto Guzzi V65
1969 Honda CB450
1978 Morini 500
Re: Gearbox whine
penman wrote:Hi Clive,
Pretty much a full strip down, though if the crank & rods are 'known good' you don't need to get them out to remove the gear cluster/selectors. The bad news is that whilst the ball bearings are obviously 'off the shelf' I couldn't find a supply of new gear bushes when I rebuilt the forgotten error 350. I suppose someone with the right equipment and skills could machine them up, but they are not just simple plain phosphor bronze (or something of that ilk) but have s sort of spiral slots in them. More likely to rattle perhaps (like mine ) than whine though.
harrymuffin
Re: Gearbox whine
Post by harrymuffin »
The 500 gearbox has a split angular bearing made by SKF which is now obsolete. There is however, a modified standard bearing that Adrian Crimp got SKF to make for him, and is listed in their catalogue as a standard special and you should be able to order. If you do strip the engine then you will be silly not to inspect the big end bearings and clean out the crankpin sludge trap which is the usual cause of the Morini big end failures as the sludge build up cuts off the oil supply to the bearings. The big end bearing from the FIAT Multiplas from the 1960s are the same size and slightly wider and better quality than the 'official' bearings, try any engine bearing stockists or specialists. I get mine from Piston Broke in Bristol, a box of four complete bearing are half the price of one shell from NLM or they were when I last bought some.
Clive
Re: Gearbox whine
Post by Clive »
Hi Penman.
Yes it is confined to 3rd gear. My bike had been stood for quite a time before I got it also, although I have done over 10,000 miles on it now with no gearbox issues - (I change the oil approx every 12 - 15 hundred mile) so I'm pretty sure it's ok. For the time being any way.
I'm considering a full strip and re-furb over the coming winter although I'm definitely a don't fix it if it's not broke type of person.
In my opinion the worse thing you can do is to be busy 'fixing them' rather than busy riding them.
I must admit the more, and harder, it is used the better it seems to run but committing that statement to ink is probably the kiss of death and it will now turn into molten shrapnel leaving me stranded 200 miles from home. Ha ha
penman
Re: Gearbox whine
Post by penman »
Hi Guys,
Many thanks for all the informative replies and my apologies for going quiet, I have had no time for interesting things the last couple of weeks!
I think I will ride it over the summer with an ear cocked for any change in this whine and maybe a strip down will be a winter job if I am still worrying about it. If I do that, I will certainly attend to the sludge trap, I'm familiar with the idea and potential problems from my Triumphs. I am obliged for the snippets of info on bearing shells, gearbox bearings and so on - these forums can be invaluable for details like this.
This whining doesn't sound good but it doesn't sound as if I have an imminent failure looming either, hopefully it'll last until winter! There are no ominous sparkly bits in the oil thank goodness. Yet!
Joe.
1984 Moto Guzzi V65
1969 Honda CB450
1978 Morini 500
