No power
No power
I broke down a week ago with my scrambler with a flat battery and showing no charge.
Has anyone else had this happen? Is there another component faulty or is it likely the alternator has packed up.
When I charged the battery it started but when I put a meter on it there was no charge.
I don’t have any wiring diagram for it. I’m in Scotland so it’s a long way to take it to NLM.
Where can I get the software to diagnose the problem.
David Gray.
David Gray.
Re: No power
Hi David,
When you say no charge, do you mean the voltage across the battery terminals does not increase with the engine running?
It could be the alternator, the regulator / rectifier or the battery itself. My car battery expired the other week after 10 years service. It just went flat. It took a charge, then went flat again. New battery restored the car to rude health.
Any decent bike shop should be able to diagnose the problem. You will need a multimeter if you want to do it yourself.
1. Voltage across battery engine not running.
2. Voltage across battery at tick over.
3. Voltage across battery as revs rise.
This would be first for me. Do you have another battery you can try?
Re: No power
As Mickey Moto says, buy / use a simple multimeter. 1. should be 12V(ish), 2. a bit more, 3. Voltage should rise to a max of about 14V.MickeyMoto wrote:...You will need a multimeter if you want to do it yourself.
If 1. is below 12V, the battery is either flat or U/S. If 3. goes above 14V, the regulator is probably U/S.
Have a look here: http://offgridham.com/wp-content/upload ... rs-usa.jpg
Re: No power
This happened to me on my 2017, Scrambler with a lithium battery. The battery was knackered. Replaced it with another non-lithium one and it has been fine ever since.
Re: No power
Sorry for the late reply.
Yes I had tested it across the terminals, engine off, tick over and revving it. There was nothing.
I was going to take it to a chap who knows about electronics and the first thing he said was it was probably the regulator.
Someone else said it could be the battery. before I take it to him I'll try another battery just to check.
Thanks for the advice guys.
David.
David.
Re: No power
I don't know about the Scrambler, but the wiring to the reg/rec on the 08 Corsaro I had melted. I caught it just before it would have shorted out.
The later 1200s have the reg/rec relocated to get more cooling but my money would be on that. If the battery charged up OK but the voltage doesn't pick up across the battery on running then to my mind it has to be the reg/rec or the alternator. As Ming implies, no owner of an Italian motorcycle should not be in possession of a multimeter!
Re: No power
I would agree about the muti meter.
I'm hoping it will be the regulator. If it's the alternator it could be expensive.
Before I take it to my electronics guy I'll try changing the battery. It's worth a try.
Re: No power
When you say nothing, do you mean 0 volts even with engine off?gray3403 wrote:Sorry for the late reply.
David.
Re: No power
Ah - in that case the battery may well be fubar - but how did it manage to start it?MickeyMoto wrote:When you say nothing, do you mean 0 volts even with engine off?gray3403 wrote:Sorry for the late reply.
David.
