have already found them her in Germany as well with the help of the number you mentioned. I´m going to try them
 Well I've never known a change of air filter make so much difference. On first pulling away for my usual test route it felt great - possibly liking the more overall correct inlet length, then I found it really didn't want to pull above 1/4 throttle under heavy load, but revving well on a small throttle opening downhill. So some re-jetting or needle height adjustment is needed. It was a bit like the Forgotten Error when I first got that going by swapping engines, so a quick experiment will be to swap in the main jets (125 rather than 130) from the PHBH28s on that (that run with S&Bs). Though going on what was said about S&Bs being restrictive that may be the opposite of what's required - it will soon be obvious! If, instead, it needs even bigger mains I'm looking forward to getting it WFO72degrees wrote:<Googles>'It must be a .....' wrote:Hi, if your filters are the source of the problem? have a look at Polini 90 degree filters with covers as an alternative to the standard air box/filters and tuck up under the tank in still air, out of the weather etc and avoid some of the problems with K&N, Ramair etc filters especially in the wet.
Hmm, they look worth a try. I shall report back after a trial on the 2C/375 and if they work well may also put some on the Forgotten Error - although that might raise 'period parts' eligibility issues
 I should have a look at the plugs first I suppose. If all else fails I'll try a 'chop'.
 I should have a look at the plugs first I suppose. If all else fails I'll try a 'chop'.Down to 117s now and at least able to persuade it get WFO. It has a massive rich flat spot at half throttle and 5000-6000 (not uncommon) but will rev good and high in a low gear and < half throttle.72degrees wrote:I'm now down to 121 mains on the 375/L5/PHBH28 with Pollini elbows/filters. Going in the right direction but still reluctant to get on a really wide throttle. I'm hoping for the odd day of better weather again soon to continue the quest. On checking, I remembered that I also had to go to a very lean needle (X1) height to get it running nicely on the S&Bs can't remember what atomisers though - must check.
 The Forgotten Error will keep S&Bs!
 The Forgotten Error will keep S&Bs! The Dellorto 28 (as well as the 26, if I´m not too wrong) are 42 mm.
