Hello,
I am rebuilding a 501 motor, when offering up a new camshaft, the cams are not sitting directly under the cam followers on either side. So maybe I have lost a spacer but wonder if I have been sold a 350 camshaft that is narrower? Unfortunately I do not have the original to compare.
Any thoughts , anyone, anyone got a spare 501 "J" cam?
Thanks Steve Pegg (East Sussex)
501 Rebuild camshafts?
Re: 501 Rebuild camshafts?
Flat cam follwers are of set so that reotate and follwer wear is more evenly distributed. On better designed engines the cam follwer surface is slightly convex to promote better rotation. As ours are flat, when they are pitted you can surface lap them with grinding paste on a piece of glass and reuse, you are unlikely to grind through the harded layer.
Thanks Harry,
It seems I have not made myself clear by pursuing brevity.
What I meant was that the center line of the cam follower is displaced from the center line of the cam lobe. Not enough for the cam lobe to overlap the followers edge but still significant to just not look right to me. This occurs when the cam is placed in either crankcase half. I have got the cam the right way round
Hopefully I have explained myself better this time.
Steve
Steve
What Harry is saying is that it is correct that the cam follower is not in the middle of the cam lobe. The centre line of the cam follower is slightly off-set to one side. This ensures the cam follower rotates when the engine is running, to avoid the cam always hitting it in the same place (and so wearing it out). That's why it is round and not square, as on a Triumph of BSA twin for instance, to allow this to happen. It's actually a very cheap solution to what could otherwise be a very expensive problem.
Hope that make sense
Pete
Pete
What Pete said.
Hello Pete,
Thank you for the clarification, I was about to PM Harry as I realised this morning that his explanation did in fact cover my question so thank you also Harry.
My "Spider sense " was on full alert as this was not the original camshaft so I was looking for anomalies.
I can now crack on with the rebuild thank you.
Steve Pegg.
Steve Pegg.
