What is the model designation of the front forks. Marzocchi __________. I'm thinking of complete overhaul instead of just seals. Even thinking of getting the gold valve emulisers .
To stop the exhaust manifold unscrewing from the head, has anyone tried lock wiring it ?
Is just one turn out on the air mixture screw getting to the stage of needing to change the pilot jet ? I feel I may even need to go to 3/4 of a turn out for it to run the best just off idle.
Has anyone tried installing a slightly less stiff springs in the carbs. I am thinking of getting a spring maker to make some, say 20% softer. Then I thought perhaps someone has already found some from another bike. A slightly lighter pull on the throttle would be nice.
Can the inside of the headlight be re chromed ? Mine has got some minor peeling. Would like to refresh it. Any suggestions ?
I love fine tuning.
