A friend is in London the 27th and can bring parts across the channel to save on postage cardboard etc
various Morini parts
Wheels, frames, engine parts etc: see listing here: https://www.marktplaats.nl/verkopers/487486.html
Re: various Morini parts
Just put some (new) parts up for sale, frames, engine parts, loads of stuff: https://link.marktplaats.nl/m1413308328
is the speedo drive complete with both gears?
i'm missing the wheel side gear in my drum 350 sport.
Yes both gears are here, but if they will fit your bike I am not sure. I'll check for measurements etc. and let you know.
On the wheel side it says 29500-201-016, on the other gear is just "Veglia"
Sizes are ø outside 50mm, the gear side, 51mm the flat side with a small recession in the middle
ø 47 mm inside
height 21 mm
I checked with the castwheel GT and they are interchangeable.
I have another one stamped 29500-201-019 Veglia (only the wheel side), don't know where that one is from but the measurements are the same.
ø 47 mm inside
height 21 mm
it is for a drum 350 brake sport ,
i have the wheel ,and the external gear, but not the gear fitted to the hub.
i'll check this weekend if it measures up.
