I need a carb slide for my 250 2c, the part number is 7447-40 . I have tried the usual places such as Eurocarb and Mdina but no luck,
thanks
Dave.
Carb slide wanted
Carb slide wanted
David
Re: Carb slide wanted
https://www.ebay.com/itm/Dellorto-7454- ... 3439285373 and a cheaper one https://www.ebay.fr/itm/NOS-DUCATI-BOIS ... Sw-q9dTEXz
Eurocarb show 10 of the 60 slide in stock.
Thanks but those are not the same part number.
David
What kind of carbs does a 250 have? I have some odd sized ones that might be useful (meaning: not for a 350 or 501
It has the VHBZ 22 HS carbs. I have the correct jets , needles ,etc .it's just on one carb the slide is a 7447- 50 and it should be a 7447- 40. This size was also used on the 125H and 250 T
thanks,
Dave.
thanks,
Dave.
David
I have a 7447-40 from my 250T. I found it was better with the 50 so changed it. I've tried to attach a couple of photos but if you need something else, PM me. As you can see there is some wear to the face but that's not why I changed it.
- 7447-40-2.jpg (55.95 KiB) Viewed 6115 times
- 7447-40-1.jpg (55.04 KiB) Viewed 6115 times
For the benefit of others who may not have seen it, there is this article http://www.thisoldtractor.com/moto_guzz ... _a_40.html which is about 7454 slides but would also apply to 7447. Unfortunately, the original article by Tatsu Okamoto seems to be no longer available due to the withdrawal of Google+.
