sump plug
sump plug
can anyone give me the thread sizes, diameter and thread pitch for the sump plug on a 1978 3 1/2 sport engine. on modern jap bike you can get magnetic sump plugs. so if i have thread sizes i can use one from a jap bike
- corsaro chris
I got some neodymium magnets from a firm called Cermag last year-nickel plated ones as it is corroded quite easily. I have araldited one under the sump plug, though it might have stayed put without. Didn't fancy it sticking onto the chain.
Anyhow I have so far not collected any manhole covers or scaffolding as I pass.They are about the diameter of the end of the sump plug and around 8mm thick. Put 2 together if you dare.You can get them apart with extreme effort and caution or you will get blood blisters as they snap together.Quite brittle too.
I should weigh the plug /residue to see if there is any increase but I have not.
I got 10 for about a tenner. If you want I can send one up. You will find the postman attached to the letterbox.
i found this one but its in US dollars which makes it expensive to ship to the uk.
we need M22 x 1.5mm thread pitch
order Number--- 1016 SM---
http://www.magneticdrainplugs.com/metric.htm
