Tank Pad Kanguro X3
Firingonone
Tank Pad Kanguro X3
The coloured tank pad above the front of the seat has always been missing from my bike and appears unobtainable (part no.32.03.39). I would be grateful if an X3 owner could give me a close up photo/diagram with some dimentions of the base plate so I can make one to go with the new seat cover when it arrives.
Re: Tank Pad Kanguro X3
I might have one lying around, I'll have a look this week
Firingonone
That would be great, please let me know if you find it .
you mean this one?
I have two, one from a X2 and a X3. Both have cracked but you can use them to make a replica from stainless sheet material so at least they won't break when your motorcycle gear grabs hold of one of the corners
Shall I make a cardboard template with measurements and post it here?
acemorini
Hello Hendre,
That would be very helpful as I need one as well.
Regards Pete.
Regards Pete.
The pad on my Coguaro is 195 x 45mm which looks similar.
If it were me in the first instance I would cut a bit of ABS and form the bends with a bit of heat. My current sheet of is 2mm thick, maybe a bit thicker would be better. You could get it covered to match. Lots of ABS sheet on eBay.Just an idea?
Firingonone
A template is just what I need. Would be very grateful if you could make up one and put it on forum.
I'll get on it today
is this enough info?
drawing was a pain, when I removed the fabric the whole thing fell apart... 80-ies plastic is not very durable
when in doublt about the shape use the right side of the piture and mirror half of it (across the fold) to the left... right side is most accurate
- IMG_20210410_145637_6.jpg (461.24 KiB) Viewed 10011 times
acemorini
Thank you Hendre,
very helpful.
Regards Pete.
very helpful.
Regards Pete.
Firingonone
Great, will get started on it, thanks for doing that.
glad that I could provide assistance
