Hi, I’m looking for advice on the correct rating for a new battery for my 350 sport 1976 ( obviously kick start only). The existing battery is a Yuasa YTX 5L - BS, 12v 4Ah and is past its best.
I was going to get a direct replacement until I checked the ‘Blue Book’ and it quotes 15Ah.
350 sport battery 1976
Re: 350 sport battery 1976
The electric start bikes had the bigger battery. I think the earlier ones had 9Ah batteries.
I use a generic SLA battery. Way cheaper & lasts for years.
- SLA battery.jpg (43.96 KiB) Viewed 5446 times
AntietamClassicCycle
I bought this one for my '77 Strada: https://www.batterymart.com/p-yb9-b-sea ... ttery.html
Charlie Mullendore
12N93B was I think the original 9 ah battery. As others have said a modern sealed battery can be had now and although it is less capacity the 4 ah you have will work fine as long as your charging system is working. Careful with some modern replacements though, they are a millimetre or two over sized in some cases and will not sit properly in the original battery tray.
Trying to increase your post count Steve?
Ha! Only just noticed that! Learning by rote, maybe?
