90 degree thingy for instruments
Hello,
I need a 90 degree bend to connect a tacho cable to the tacho.
Does anybody have one, please, or if not the part number.
Thanks,
AntietamClassicCycle
Re: 90 degree thingy for instruments
Likely the same as used on Moto Guzzis?
https://www.gutsibits.co.uk/pr/TheShop/ ... rch=SEARCH
Yes!
Thank you.
Post by julianharty »
Charlie,
that was timely, I've ordered one as mine packed up and caused the speedo needle to wave wildly.
Mick you'd better be quick as there's only one more listed in stock...
Thank you
Julian
Post by simonnorthroad »
Yes as used on many Guzzis. Eyewateringly, bafflingly expensive and always have been.
Yes, but it works. The problem stemmed from a tacho cable that is too long. It appears to be a Kanguro cable. Venhill do not appear to make them. I will need to learn to make my own.
hombre
Post by hombre »
they are on the Excaliburs too, so shouldn't be too hard to find
