Fibre Clutch plate thickness
250 2c- the Wee-WeeVees
mbmm350s
Post by mbmm350s »
Can anyone help and measure some 250-2C fibre clutch plate thickness please. These might be the same as 125H (3.0mm).
buzby
Re: Fibre Clutch plate thickness
Post by buzby »
Only four years after you first asked this Mark, :) I can say mine are 2.7mm thick so some wear on mine I expect.
Can I ask if you do the clutch spring nuts up fully or back them off a few turns ?
thanks,
Dave.
David
Do them up fully, but no need to torque them up too hard. Just nipped into place is fine.
buzby
Post by buzby »
Thanks Steve.
David
