Camel Mk2 front upper chain rubbing block wanted or dimensions / pictures of the same so I can reproduce one.
Kamel.
WANTED - Camel Mk2 front upper chain rubbing block.
Re: WANTED - Camel Mk2 front upper chain rubbing block.
The one on the rear fork you mean? In Italy some guy is reproducing them, https://www.morinispecial.it/forum/Merc ... l?start=32
'It must be a .....'
Slightly shorter than the original yet it fits the Camel twin shock swinging arm
https://mckresy-it.translate.goog/prodo ... pto=nui,sc
https://www.ebay.co.uk/itm/165430311819 ... 5430311819
The ebay item Ian mentioned looks a lot like the one I used on mine. I got mine from Inmotion trials, it was meant for a Bultaco and cost about the same.
Thanks both, I’ll take a look.
Cheers.
Cheers.
Hi all,
I ordered the eBay one, and although I was dreading fitting it, it went in quite easily once I "persuaded" the outer bracket a bit further out.
Thanks to all for the help.
Kamel.
Kamel.
