What is the correct/recommended length of the preload spacers in the front forks?
Mine has 25mm on the left, 35mm on the right...
Preload spacers in front forks?
Re: Preload spacers in front forks?
I wish I could tell you, but it's been a long time since I had standard forks on my dart (I changed to mk1 mito for a number of reasons)
I am pretty sure from memory that they do indeed have different spacers left to right. And different spacers to freccia too, so if you were to fit freccia forks you would want to use the correct dart spacers
I think mine are correct. I was a bit surprised that they were different on each side, but there's no sign of anything having been modified...
