exhaust halfrings on Dart 400 ???
The Cagiva era Morinis
mantaray
Post by mantaray »
Today the ringnut of the exhaust came loose.
Didnt see any halfrings like on the 3 1/2.
On de Dart pdf i have found them but they dont have a partnumber.
Are they used on a 400?
Post by morini_tom »
It's been a long while since I had a standard dart exhaust but I'm fairly sure there are no half rings on the dart system.
My 350 uses a standard exhaust gasket. The front one used to come loose but the addition of wire wrapped around one of the teeth on the nut and the frame has stopped that now!
regards,
mantaray
Post by mantaray »
Thanks, i sleep much better now :-)
corsaro chris
Post by corsaro chris »
No half rings on the Dart, as the exhaust pipes split and so you can slide the nut up the pipe (assuming that you can split the system after all these years...)
