clutch spring nuts seized
Maestro, SEI-V
Tim
Post by Tim »
Tried using the proper tool but none would budge even with wd40 on the threads. I was thinking of applying some heat but not sure if that might cause some damage which I want to avoid if at all possible. It looks like the clutch has never been stripped....
any suggestions??
RobinSF1
Re: clutch spring nuts seized
Post by RobinSF1 »
WD40 isn't a very effective penetrating oil. Plus gas or loctite freeze and release are more effective. Worth reying one hf these before resorting to more brutal means. Doesn't always work, but a good start.
Tim
Post by Tim »
Thanks - never heard of freeze & release but have ordered some - I'll report back on how I get on!
Stempy
Post by Stempy »
Have you tried the melted candle wax release method ?
Never tried it but worth a go ?
Richard
Post by Richard »
What is "the melted candle wax release method"?
If it´s only one or twoo nuts that are locked I prefer destroying the cups of the springs with a rotaflex instead of using too much force with the danger of loosening the studs in thebarrel. To find a barrel in good conditions is much more dificult and expensive than a pair of theses cups. Cutting the fold of the cups carefully you can get out cups and springs. Then get the barrel out and you have more posibilities to get the nuts off. Even easier if it´s not an old barrel with round studs but the later one with hexagonal studs.
Tim
Post by Tim »
sadly they're all seized but take your point ie spring nuts are more easily replaced. Still waiting for the freeze 'n' release to arrive so will give that a whirl first
Good squirts of releasing fluid won’t go amiss either. I have taken to using a very small amount of Rocol Dry moly burnished onto the threads.
Tim
Post by Tim »
well the good news is that the freeze and release worked like magic - squirted for 5 seconds (oo err missus) then waited for two minutes and bingo. However the clutch plates are another story - delaminating as I removed them.
Hey ho more expense....
acemorini
Post by acemorini »
Hello Tim,
Freeze and release was a success then, must get a can for future use.
Regards Pete.
Tim
Post by Tim »
yep - all 5 seized and all five freed of with one application
acemorini
Post by acemorini »
Hello Tim,
Thank for the recommendation, I have a can on order.
Regards Pete.
Tim
Post by Tim »
Anyone know of a source of clutch plates for a 500 (Mdina have no stock) ? Also does anyone know what models use the same plates?
350/500 are all the same and if no stock at Mdina then try Stein Dinse in Germany. Failing that I have plenty of used but usable plates. Only the dished type I'm short of. I think I saw Mdina had those in stock when I last checked.
If you want some used stuff I'm in South Leicestershire UK.
Tim
Post by Tim »
thanks Steve - much appreciated. I'll try Stein dense and if no luck I'll pm you about your plates - I'll only need the friction plates
By the way are Kanguro plates different - they seem to be available in some places?
