Gp relays
MysterG
Gp relays
Post by MysterG »
I think I might of cooked up, could other members with a GP which of the four relay does what and the amount of pins they have? Sorry to be a pain all help is grately appreciated. Gordon
Painter
Re: Gp relays
Post by Painter »
I will get back to you, as I have replaced most of mine.
Tinker
Re: Gp relays
Post by Tinker »
They are all 5 pin “micro relays diode” as far as I am aware
drego
Re: Gp relays
Post by drego »
At least for the Corsaro one of the relais (I believe the load relay feeding the gas pump) must not be a diode, but a resistor-type relay. NAIS/Panasonic ACM33221 (datasheet avaiable on the Panasonic website) are a good choice. For the remaning relais both, diode as well as resistor-type, work.
BR
Robert
MysterG
Re: Gp relays
Post by MysterG »
Cheers Rob
