Evening everyone, i nice easy question for a tuesday evening. What are the recommended tyre pressures for a 350? Currently running BT45, and i can remember Alex once telling me i should run them higher than the manual suggests but cannot remember exactly what he said!
Any advice anyone?
Many thanks, Tony
						Tyre Pressures
Re: Tyre Pressures
Modern tyre carcases are much more flexible and need more pressure. In some cases running the 'book' pressures can result in the tyre shifting and shearing the valve off the inner tube.
Start high and work you way down until you like the feel. I run something like 32 front and 34 rear with Avon Roadrunners.
