Anyone found a paddock stand to fit the slots in the Corsaro
DaveH
Post by DaveH »
Fed up with struggling to get mine on a conventional 'cup' stand and can't be arsed to put it on th abba stand everytime i park it up.
Anyone found or adapted a paddock stand to fit the slots under the swingarm ?? :?:
Dave H
Dave H
Beta RR300 :mrgreen:
Re: Anyone found a paddock stand to fit the slots in the Cor
Post by morini_tom »
Newer corsaros have hollow spindles, older ones have counterbored solid ones. You can use either a solid bar or pins through the paddock stand, either by removing the cups from your existing paddock stand and fabricating something or by buying one of the paddock stands that north Leicester motorcycles sell for the corsaro. My one from them is very stable.
Obviously if you want to remove the rear wheel you can't use this method but 99% of the time it's perfect
DaveH
Post by DaveH »
Thanks Tom,
I was referring to the slots cut into the swingarm along the bottom edge - may adapy a set of conventional cups with a 'blade' to engage them....just wonderd if such a ting already existed.
Dave H
Dave H
mcalvey
Post by mcalvey »
How about this. Put it through the hollow rear axle and push/pull the bike back.
Price and details at the bottom of this page:
http://www.northleicestermotorcycles.co ... morini.htm
http://www.northleicestermotorcycles.co ... 0stand.jpg
mcalvey
Post by mcalvey »
Corsaro axle stand.jpg (81.5 KiB) Viewed 10507 times
DaveH
Post by DaveH »
Thanks for that -
looking at the pics it seems all I need is a length of steel bar to pass through the eyelets of one of my existing paddock stands !! :D :D
Dave H
yep- That's exactly what I was trying to describe! :D
Beveldrive
Post by Beveldrive »
I've got an "Rjays" universal stand for my Veloce, no pins, no probs, quick & easy, reliable and good looking. It's also got wheels so you can roll it back and forth (carefully) while it's on the stand.
Cost me under $100Au.
