Strada left bar light switch wanted
Monstyr
Post by Monstyr »
I think it may be a 'series 2' lightswitch I'm looking for, I only need the actual top switch part so a non working one could still provide donor parts, and it could be a common part used on several models(or other makes for that matter)
DSCF5888 (Medium).JPG (80.19 KiB) Viewed 5285 times
"The problem with quotes on the Internet is that you can't tell whether or not they're genuine" - Abraham Lincoln
hendre
Re: Strada left bar light switch wanted
Post by hendre »
if you are throwing the old stuff in the bin I am interested in the left knob (the plastic bit screwed on with a philips head), on my Duc 860 mine split in two bits :)
Monstyr
Post by Monstyr »
I'm reusing the switch I'm afraid, but if its any help I got the bit I needed from a Yamaha RD125lc switch which is mechanically identical though the wiring is slightly different.
hendre
Post by hendre »
OK, thanks. Yam switches are cheaper to get by then Morini, Duc, Lav...
