Broken ecu plug, Low beam relay, Diagnose: right side fan
Tonto
Post by Tonto »
Hi Guys,
My corsaro has problem with right side fan. Diagnose text: Right cool fan s.c. gnd. Any ideas what I should do next? Relay? Where is fuse for fans and is there individual fuse for both fans?
Bike does not have low beam relay for some reason. Can you help me to find one.
As you can see from pics connecting plug (plug to ecu) has damaged? Do you know that should there be something or just empty holes.
Toni
From Finland
backfat1187
Re: Broken ecu plug, Low beam relay, Diagnose: right side fa
Post by backfat1187 »
I have a colour wiring diagram but its too big a file to send via the forum and I can't remember where I downloaded it from. Can you PM me your email and I'll send it.
Fuses are under the rear seat near the ecu.
You need one of these for your low beam
http://www.vehicle-wiring-products.eu/p ... cro-relays
Tonto
Post by Tonto »
Thanks backfat1187!
Question about ecu pins. Which one is number 1 pin, 2 pin and son on...?
ecu pic.PNG (53.4 KiB) Viewed 7839 times
backfat1187
ECU pinout.PNG (136.04 KiB) Viewed 7831 times
