Sync Throttlebodies 9 1/2
augbjo2000
Post by augbjo2000 »
Hi !
I have tried to syncronize the throttlebodies on my Morini 9 1/2 ( not very sucessful - i must admit)
I just followed the instructions - but the result wasnt so good.
I have to try once more - any thricks that makes it easier?
" Use the vacuummeter to check witch of the to intake galleries that have the highest vacuum pressure - and react on the corresponding screw -witouth adjusting the intake with lowest vacuum pressure. "
when I adjusted - i opened the screw a little - to level the vacuum in both galleries - hopefully this is correct ?
I start wonder if one of the two throttle bodies gets " false air" - anybody that have experienced that
The engine starts "puffing" a lot afterwards - have I used wrong procedure here ?
anybody that has any experice to share with me :-)
Re: Sync Throttlebodies 9 1/2
Hello,
If I remember correctly, you should screw in both screws to the stop and then only adjust one screw.
I have attached two screenshot from the Milano manual...
The quality is poor due to site limitations. If you have difficulty reading the screenshot let me know and I'll attempt to change the quality.
Lykke til...
Mike
Screenshot_20210902-150831_Adobe Acrobat__1630592182_86.174.66.164.jpg (30.02 KiB) Viewed 14874 times
Screenshot_20210902-150916_Adobe Acrobat__1630592092_86.174.66.164.jpg (34.47 KiB) Viewed 14874 times
hendre
Post by hendre »
I have extracted the pages from the 9 1/2 manual, you can download them from WeTransfer for 7 days
https://wetransfer.com/downloads/5f6a3c ... 027/267ec2
augbjo2000
Hi , I have the workshop manual for the 9 1/2 so thats ok
Thanks for the info - I have used the correct prosedure - I have to take a new check
Wish me luck :-)
augbjo2000 wrote: 02 Sep 2021 17:54
Wish me luck :-)
Lykke til
augbjo2000
Problem solved :-)
The rubber tube between the intake and the throttle body on the rear sylinder was not properly fastened. -with “false air” as a result.
When this was sorted -the synchronization process was successful - and the engine react very well on the adjustment. :-)
Still I think the injection should be tuned some areas around 3 000 rpm - 4000 rpm where the bike don’t run smooth
I don’t have any experience with software upgrade - anyone that know what’s needed ? - and does Ducati workshops have what’s needed
The ECU are similar to some for the ducc bikes.
Look for TuneEcu, they have maps. Others may be available.
