wanted: clutch lever, mounting bracket and adjuster assembly
bowman3761
Post by bowman3761 »
Does anyone have a clutch lever assembly for a 350 Sport 1977, ideally in black? The clutch lever fitted to my newly acquired bike is non-standard, and its mounting fits between the electrical switchgear and the clip-on grip. Consequently, the switchgear is further away and difficult to use, and I’m unsure as to whether I’m getting the correct cable pull for the clutch.
Can anyone advise the correct cable pull from a standard lever, or make recommendations for an affordable and available substitute. The pull on my current (non-standard) lever is 17.5 mm, fully-closed-lever-to-fully-open. Thanks, Tim
clutch lever 2.png (451.56 KiB) Viewed 2653 times
