Gas tank rubber retention ring
Tresette61
Post by Tresette61 »
Members, any one know where one can acquire the rubber retention ring which holds the rear of the gas tank in place? I see Mdinaitalia lists it on their web site, unfortunately they are out of stock. Mine has finally broken.
Regards Clark Bertram
FatherB
Re: Gas tank rubber retention ring
Post by FatherB »
I've used Hoover vacuum cleaner rubber drive belt rings for years. They do the job on my Strada and seem to last quite well. The one currently on my bike has been there about 5 years and is still good. Your local vacuum cleaner spares stockist should be able to sort you out with one.
Tresette61
Father B. thank you for the suggestion. I will check out Hoover vacuum parts vendor.
Martha
Post by Martha »
An alternative that I have used is an 'o' ring of suitable dimension sourced from ebay.
Incidentally, the foam rubber pad(s) that sit under the tank on the frame spine are close enough to those fitted for the same job on the 750/850 Norton Commando and the rubber buffers at the rear corner of the tank are as near as dammit those fitted to Norton Dominators.
Yes, as already said-washing machine/vacuum cleaner spares! As for the support pad the originals will have crumbled away years ago and were only a cheap piece of porous foam anyway. I started cutting up old camping mats-closed cell foam and cheap enough. The originals were also a bit marginal on thickness and I find 2 x camping mat bits cushion it nicely. I don't camp much these days either!
For years I've been using the the large rubber seals from car oil filters which last for years.
Worth asking at a garage if you don't do your own car oil changes.
Vitesse
Post by Vitesse »
Mine has a piece of rubber clearly fashioned from inner tube. Not pretty with a big knot in it but effective.
BumbleBee
Post by BumbleBee »
Mine simply has a wide black cable tie :D Not tight, just enough to allow flex on the rubber foam the back of the tank sits on.
