350 swinging arm spindle
acemorini
Post by acemorini »
Hello all,
I am looking for a swing arm spindle for a 1979 sport kinked frame, failing that anyone got a drawing for one, I know there like rocking horse _hite, but you never know.
Regards Pete.
Re: 350 swinging arm spindle
Tried Doug at Mdina? The site advertises swinging arms if you have a part number?
Have you tried to turn the Spindel 1/4 turn? This can help some thousand km :wink:
hombre
Post by hombre »
I bought one from Dieter Hoffman, the hardened version that you can use with roller bearings. morinicorse1 -at- aol -dot - com
It's a while ago but maybe he still has one or two
Hombre,
Best regards to Dieter and Sören when you meet them in Morano!
If you ever come down close to Valencia, let me know. With that nickname you should do so :wink:
hombre
Post by hombre »
norbert wrote: 20 May 2025 08:12 Hombre,
Yes will do Norbert!
acemorini
Post by acemorini »
Thanks for all the replies, yes turned the swinging arm spindle a few years ago go, but now there is a slight bit of play , so time to find, make a new one.
Regards Pete.
Tried new bushes? I would think they wear quicker than spindles.
MickeyMoto wrote: 20 May 2025 20:32 Tried new bushes? I would think they wear quicker than spindles.
I think it' s the other way, the wear of the spindle is the main problem. It's realy rare to find a used sindel in good condiciones.
FatherB
Post by FatherB »
My swinging arm spindle was slightly worn. I had it ground down by about 5 thou overall and turned up some undersize bushes in phosphor bronze. I then reamed them to fit the undersize spindle. All good after about 8,000 miles. I grease them every 500 miles with a few strokes of the grease gun.
