Voltage regulator wiring?
Motomat350
Post by Motomat350 »
Hello Morini experts :D
Does anyone know how to wire a new voltage regulator?
It has 6 terminals :!:
Happy riding 8)
Morini 1.jpeg (465.27 KiB) Viewed 5268 times
Morini 2.jpeg (463.59 KiB) Viewed 5268 times
Re: Voltage regulator wiring?
We're you given a wiring diagram with it?
Why is there a green wire on your old reg/rec? Green is ignition. There should be two yellow wires from the alternator.
Motomat350
No unfortunately not.
I don’t know, guess I have to check is the green are supposed to be yellow :shock:
Parker3865
Post by Parker3865 »
This for a ducati, no idea how you would translate that to the Morini wiring
ducati rectifier wiring.jpg (162.07 KiB) Viewed 5231 times
Motomat350 wrote: 27 Sep 2025 14:18 No unfortunately not.
Looking at the picture, it looks like the reg rec has been moved to the toolbox. It does not look standard.
123morini
Post by 123morini »
Hello ,
here is a wiring diagram of first model .
Capture d’écran 2025-09-30 125235.png (116.4 KiB) Viewed 5140 times
Christian .
Does this help?
viewtopic.php?t=3532
